Re: Won't Start
Posted by Bob on August 15, 2014 at 08:58:08 from (64.255.159.192):
In Reply to: Won't Start posted by Fred Find on August 15, 2014 at 08:46:13:
" Filled it until we could see the oil topped to the cap. "
Around here, that"s called an "Al Miller Maneuver".
Likely, there are two petcocks on the side of the oil pan. You should have opened the top one and added oil "til it slowly dripped out, then closed it and installed the 710 cap.
After 30 years, likely it has rotten gas and probably corroded breaker points.
Post a photo, so guys can positively ID it and I"m sure you"ll get lots of help!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
