Won't Start
Posted by Fred Find on August 15, 2014 at 08:46:13 from (206.180.152.74):
My sister and I inherited my uncles farm, we moved from the city out to the old plantation, we found there is a lot we do not know and appreciate your help. Old Farmall tractor with the steering gear above the front wheels, shaft runs over the top. Siting in the barn for over 30 years, uncle never got around to using it. Figured we needed to change oil, called several people, they said drain old oil and fill with new. Did as instructed, cannot get it started. Funny thing, never knew a tractor would take 52 quarts of oil. Filled it until we could see the oil topped to the cap.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
