Posted by Arnold Layne on August 15, 2014 at 10:09:55 from (66.146.251.74):
In Reply to: Won't Start posted by Fred Find on August 15, 2014 at 08:46:13:
Well, if this is indeed true, I guess I can't kick you around IF you have never changed oil in anything before. But would one not notice that four or five quarts came out? If you did drain 52 qts. out that may be a sign of why it won't run. If you did put 52 qts. of oil in it, that is one reason why it won't run. Any F Farmall I have owned would have had oil falling out of the governor before it got that full. Seems like it should be pouring out of thee vent pipe too. Just sayin.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
