Re: Farmall C Instant Load When Power Switch Turned On
Posted by farmallhal on August 15, 2014 at 12:10:55 from (67.139.43.106):
In Reply to: Re: Farmall C Instant Load When Power Switch Turned On posted by rustyfarmall on August 15, 2014 at 12:05:19:
Thanks Rusty as I knew it was one way or the other but thought is was when the circuit is closed with both surfaces of the points making contact, Hal.
