Re: Farmall C Instant Load When Power Switch Turned On
Posted by rustyfarmall on August 15, 2014 at 12:05:19 from (208.126.186.41):
In Reply to: Farmall C Instant Load When Power Switch Turned On posted by farmallhal on August 15, 2014 at 12:01:35:
YES, if the points are closed when the switch is turned on, the amp gauge WILL show a discharge. If the points are open, the amp gauge will stay at zero.
