Posted by DeltaRed on August 15, 2014 at 12:30:19 from (67.40.59.57):
In Reply to: Won't Start posted by Fred Find on August 15, 2014 at 08:46:13:
If you look at my '20' you will see 3 petcocks on the oil pan side.Let oil drain down to the top one.That is the full level.The bottom on is the 'low' level.When oil no longer comes out if the bottom,add approxamately 1 qt till oil comes out the top again.Look on Google images.Type in'Farmall F series' there will be lots of pics to help you identify.There were 5 F series modle tractors built: 'Regular'(24-32); F12(32-38) ; F14(38-39); F20(33-39); F30(31-39)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
