Re: Won't Start
Posted by John M on August 15, 2014 at 12:39:50 from (68.115.194.228):
In Reply to: Won't Start posted by Fred Find on August 15, 2014 at 08:46:13:
Sounds fishy to me, but Ill take your word for it. As mentioned, 30 years is along time, and things are bound to be wrong. First, a picture will help a lot. Then we can go from there to help you.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
