Re: What did I do wrong? Farmall H carb leaking fuel
Posted by David G on August 15, 2014 at 21:35:02 from (97.127.191.147):
In Reply to: Re: What did I do wrong? Farmall H carb leaking fuel posted by John M on August 15, 2014 at 05:11:11:
I would agree with John M, if it runs and does not leak then, all is fine.
