Re: What did I do wrong? Farmall H carb leaking fuel
Posted by clint s on August 16, 2014 at 06:30:57 from (67.242.45.169):
In Reply to: What did I do wrong? Farmall H carb leaking fuel posted by David G on August 15, 2014 at 21:35:02:
X3. My 200 will do the same thing if it does not start after a few tries, especially if you use the choke.
