You do know the Cub PTO turns backward form the C. I would turn the tedder backwards to see it it will work try and turn it both ways then you would know if it will work on the Cub.The tedder probably will run in reverse if its on the Cub but it is easy to just turn the shaft both ways to see.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
