Cub offset PTO question
Posted by agauthier on August 16, 2014 at 14:22:08 from (74.69.244.223):
I am thinking about buying a Cub to pull a small hay tedder (10ft, two reels). It looks in all of the pictures like the Cub PTOs are offset to the left--does that matter? I usually pull the tedder with a Super C which has the normal centered PTO.
