Re: Cub offset PTO question
Posted by old on August 16, 2014 at 15:11:17 from (209.86.226.27):
In Reply to: Re: Cub offset PTO question posted by agauthier on August 16, 2014 at 14:53:30:
PTO on the cub smaller plus it is not even the normal splines like most if has like 21 splines. Not the exact number but an example and they are what would be termed a fine splines shaft
