Re: Cub offset PTO question
Posted by willie in mn on August 16, 2014 at 17:42:50 from (64.12.116.77):
In Reply to: Cub offset PTO question posted by agauthier on August 16, 2014 at 14:22:08:
Cub PTO turns the other way because it is direct drive from the crankshaft. Ergo, if you run engine at 1200rpm , that is also PTO speed. The only way to get it down to 540rpm is to run engine at slow idle, or a reduction box/pulley setup.
Willie
