Bad plan! Cub is only 10 HP. PTO Turns at engine speed so no good way to get 540 RPM for the Tedder. PTO turns opposite direction to normal PTO. PTO shaft is smaller than standard and will not hook up to your Tedder. The offset of the PTO would not matter as PTO shaft on Tedder is usually long so that U joins would easily handle the offset. You can easily find another C on the cheap that will do your job. Plenty of Cs out there.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
