You should pull off one plug wire at a time while a helper makes an attempt to start the engine to see if you have hot fire to your plug. If the fire looks weak your coil may be weak. Check your distributor cap for a crack. Do a compression check to see what your readings are and check the valve lash to see if they have enough clearance. Make sure the helper has the brakes locked and the transmission is out of gear. New points and a condenser may be in order. Hal PS: APG is taking a cut in personnel somewhere around 5000. This is what our local paper has posted. The traffic is terrible in that area and not much better in Bel Air.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
