Re: Cub offset PTO question
Posted by BMD on August 17, 2014 at 11:54:51 from (107.4.214.137):
In Reply to: Cub offset PTO question posted by agauthier on August 16, 2014 at 14:22:08:
Cub PTO is 15/16 inch pitch diameter, 10 tooth involuted spline and as other have stated it turns counter clockwise at engine speed. (approx 1,000 RPM)
Standard PTO is 1 3/8 6 spline that turns 540 RPM clockwise.
To use the Tedder would require an adapter to mate PTO to tractor and you would still be turning the Tedder twice the rated speed in the wrong direction of rotation. Probably not a good idea if would even work.
Tisco at one time made a adapter to adapt standard shaft to PTO, not sure still available. Hub City at one time made a rotation reverser and speed reducer but they are very rare, if impossible to find.
