Posted by SDE on August 17, 2014 at 16:31:16 from (174.124.63.138):
I assume that to correct this problem, I will need to pull the head, pull out the piston and remove the sleeve. If the bore in the block is ok, then what do I do? Is the sleeve suppose to be a tight fit? If it is too loose, is that why the coolant is getting in the oil? If I get it fitted properly will the leaking stop? I don't think it is a head gasket problem, because I have not lost much coolant and it has not been over heating. Thank you Steve
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
