Re: #3 sleeve is leaking coolant into oil pan (400)
Posted by rustred on August 17, 2014 at 18:30:37 from (74.214.152.80):
In Reply to: #3 sleeve is leaking coolant into oil pan (400) posted by SDE on August 17, 2014 at 16:31:16:
yep, pull head, examine gasket for sealing. pull sleeve examine bore for cracks, as that is the most likely problem. sleeve will need a puller to get it out if you want to save it. otherwise can run a couple welds from top to bottom and it will pull out with your fist. sleeve fitting has nothing to do with the leakage. I have used green locktight on those stress cracks in the block and put them together and no problem. the sleeve takes a good push by hand when reassembling it.
