"Seems to be enough gas" unhook the line at the carb and run a gallon out, if the flow it not the same at the end as the beginning then start looking there. Next is take the plug out of the bottom of the carb, then move into the the carb. There are no short cuts in a diagnoses,start at the front and work your way down line. My mower quit running and I knew the fuel pump quit so I bought a new one, (I should have looked a little more) it was a bad wire crimp, and now I have a 50.00 pump setting on the shelf.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
