706 gas engine not getting enough gas to pull
Posted by David Truesdale on August 17, 2014 at 18:42:35 from (71.28.88.156):
my 706 gas got to where it would not even pull a bush hog or small bottom plow. put in a car. kit and now it will not even run with out the chock pull out. the idle scree has no effect all the way in or the way out. checked the fuel line from gas bowl to the car. seems to be enough gas. need some advice. thanks John
