Re: 706 gas engine not getting enough gas to pull
Posted by mkirsch on August 18, 2014 at 07:02:26 from (72.45.143.81):
In Reply to: 706 gas engine not getting enough gas to pull posted by David Truesdale on August 17, 2014 at 18:42:35:
With the fuel line disconnected at the carburetor you should be seeing a full stream of fuel out of the line continuously, with no sputters or dribbles or anything. Just straight fuel.
Also, "putting a carb kit in" is not a guarantee that the carburetor will work right afterwards. You've got to clean everything and put it back together correctly. Float setting is crucial, and the float is kinda delicate. If you ding it a little you can cause it to rub on the side of the carburetor bowl and then it won't move properly, and can choke off the flow of fuel.
