Re: 460 utiltiy gas rough start...
Posted by Butch WI on August 18, 2014 at 18:06:07 from (172.242.179.115):
In Reply to: 460 utiltiy gas rough start... posted by Butch WI on August 17, 2014 at 05:47:54:
Well I tried the spare set of points I had for an H. Could only use half of them and you will see why in the photos...Can you tell me why there is different ones that I got from the dealer today from the ones it has in it???? Check out the pics.
third party image
third party image
third party image
third party image
You can see the differences...have to "modify" the new ones where the shaft rotates on and then use the old rigid part becuse there is no lobe that offsets on the new ones rendering them useless.
BUtch
