Oil leak on 1206 on bottom ?
Posted by larryanderson on August 18, 2014 at 23:08:13 from (99.196.155.104):
Right where you would split a 1206 there are two removeable plates on bottom of tractor toward rear.One is thinner and smaller and that's were it appears hyd fluid is leaking.Its not black enough for engine oil which would make you think rear main.Probably something drive train related.Any ideas or will it have to be split? I had it at a show and just drove it home 20 miles as it was so nice and leak appeared. Fluid levels didn't show much difference. Thanks
