Re: Oil leak on 1206 on bottom ?
Posted by catman13 on August 18, 2014 at 23:27:54 from (24.20.178.64):
In Reply to: Oil leak on 1206 on bottom ? posted by larryanderson on August 18, 2014 at 23:08:13:
does the plate have 2 bolts holding it on?
sounds like your transmission front seal is leaking, if that is it you will have to split it in half .
there is also a cover on the bottom counter shaft that is held by 3 bolts ande has a basket in it , if this leaking you should be able to change the gasket with out slitting the tractor.
hope this help
