Compression will push your finger off the hole BEFORE the piston hits TDC. You need to shine a light down in the spark plug hole after your finger gets blown off and visually ensure the piston is at the top of its stroke.
A/B/C engines are nice because you can visually see the piston at TDC through the spark plug hole.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
