Re: Farmall A - firing order [hooking up missing plug wires]
Posted by wayne in mn on August 19, 2014 at 05:54:45 from (71.8.150.168):
In Reply to: Farmall A - firing order [hooking up missing plug wires] posted by gdtractor on August 18, 2014 at 22:37:45:
UNLESS SOMEONE HAS REMOVED & PUT THE DISTRIBUTOR BACK "INCORRECTLY"
the wires should be: 2 1
3 4
or very close to this position.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
