Re: Farmall H output shaft oil seal
Posted by D Slater on August 23, 2014 at 16:08:24 from (184.14.176.27):
In Reply to: Farmall H output shaft oil seal posted by mike farmer on August 23, 2014 at 14:13:58:
If its the output or counter shaft driving the liftall, the slotted drive coupling nut is standard or right hand threads. Remove it and the three bolts retaining the seal housing. Remove it and replace the seal. Housing also originally uses a gasket to transmission housing. Transmission oil will come out when removing unless drained down or front of the tractor pretty high up.
