Farmall H output shaft oil seal
Posted by mike farmer on August 23, 2014 at 14:13:58 from (109.154.100.118):
Greetings. I have an oil leak at the output shaft oil seal on my 1945 H. I've disconnected the lift-all drive to check and there's a serious amount of oil around the coupling each time I run the tractor. I've never needed to do this job before so any advice would be good. My main concern is whether its a standard Right Hand Thread because I certainly don't want to cause any stupid damage. So I would really appreciate any help, suggestions or advice that you can give. Thanks in advance. Mike Farmer
