There is a right way and a get by way to work on that shaft. The right way is to pull the housing with the shaft and bearings. Held in with them six bolts. Then you can repair it right, checking the bearings for wear and more importantly, be able to access the transmission pilot bearing which was the highest failure rate bearing in the H tractor. You need to pull the belt pulley drive off to do this or you will damage bearing putting it back together. I have seen more than a few put back together where the half moon key moves back up the key slot and then it damages the yoke when bolted down tight.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
