Re: What did I do wrong? Farmall H carb leaking fuel
Posted by Redturbo on August 23, 2014 at 22:27:43 from (66.112.187.143):
In Reply to: What did I do wrong? Farmall H carb leaking fuel posted by Redturbo on August 14, 2014 at 21:55:52:
The gas has seemed to stopped coming back out the carb mouth. But the engine is only running on cylinders 3 & 4, can pulled 1 & 2 plug wires off & makes no difference. The spark plugs are wet on 1 & 2. So I did a compression test, have 120 psi on all 4 cylinders. I did replace the intake/exhaust gasket. Any guesses?
