Re: What did I do wrong? Farmall H carb leaking fuel
Posted by clint s on August 24, 2014 at 07:54:50 from (67.242.45.169):
In Reply to: What did I do wrong? Farmall H carb leaking fuel posted by Redturbo on August 23, 2014 at 22:27:43:
Bad plugs, plug wires, firing order, bad cap, timing(???)
Pull the wire get a new plug and check for spark. If you have a good spark change the plug.
Place wire 3 on terminal 2 to see if it is the wire. If it follows the wire they are bad
Check the cap for carbon or crap.
Just thoughts and easy to do.
