Re: starter motor will not stop running
Posted by old on August 24, 2014 at 15:47:15 from (209.86.226.34):
In Reply to: Re: starter motor will not stop running posted by homebre973 on August 24, 2014 at 15:12:54:
That is why I said to trace where the ignition side battery cable goes it will go to a solenoid. Or trace back from the starter it should have a big cable on it and that in turn goes to the solenoid
