Re: starter motor will not stop running
Posted by homebre973 on August 26, 2014 at 06:10:48 from (134.67.237.244):
In Reply to: starter motor will not stop running posted by old on August 24, 2014 at 15:47:15:
Thanks to everyone. I did find the solenoid--it was mounted away from the starter motor. I saw a picture of one on the net, so that enabled me to locate it. I hit it with a piece of metal (lightly!), and then connected the battery with the ignition switch not connected, and the starter did not run (good!). So this seems to be the problem. I have not had time to hook up the ignition again, but will try this weekend.
