Re: ih 504 diesel new head gasket but popping loudly through ...
Posted by Bob on August 25, 2014 at 08:49:24 from (64.255.159.192):
In Reply to: ih 504 diesel new head gasket but popping loudly through ... posted by essexfarmin on August 25, 2014 at 08:16:57:
Did you keep the pushrods in order, and re-install them in the same location?
Did you carefully set the valve lash?
Have you looked under the valvecover to see if there's a bent pushrod, a pushrod out of place, a stuck valve, or a lash adjusting screw that has worked loose?
