Re: What did I do wrong? Farmall H carb leaking fuel
Posted by Redturbo on August 26, 2014 at 23:03:58 from (66.112.187.143):
In Reply to: What did I do wrong? Farmall H carb leaking fuel posted by Redturbo on August 14, 2014 at 21:55:52:
Sprayed brake clean around the intake/exhaust manifold, engine did not rev up, so Im assuming that its sealed to the cylinder head. Took spark wires off the W450 that runs. Still no better. Put the old cap & rotor back on, have spark on all 4 now. When I pull wires on each cylinder, can hear a difference in the way the engine runs. Set the screw on the bottom on the float bowl to 2/5 turns out. Set the other screw to 1.5 turns out. Seems to getting better, but there is flutter/miss every once & awhile. I don't have a timing light, I marked where the dist was. Moved it back & forth till it sounded better. The flutter/miss is still there, but not all the time. Can the governor & dist does this?
