Re: What did I do wrong? Farmall H carb leaking fuel
Posted by clint s on August 27, 2014 at 06:09:53 from (67.242.45.169):
In Reply to: What did I do wrong? Farmall H carb leaking fuel posted by Redturbo on August 26, 2014 at 23:03:58:
. Did you change the plugs, even new plugs can be bad from the box and cause a miss.
