Re: 8 volt battery in a Super M
Posted by mkirsch on August 28, 2014 at 05:13:42 from (72.45.143.81):
In Reply to: 8 volt battery in a Super M posted by Paul A Young on August 27, 2014 at 20:31:45:
You have run into the major disadvantage of an 8V battery:
Nothing is designed to charge an 8V battery.
Electrical systems are 6V or 12V. 6V won't charge it. 12V will ruin the battery.
I'm not sure you can even get a battery charger that will properly charge these batteries.
You can fiddle with the regulator as suggested and it MIGHT work, but then again your generator may only be capable of putting out about 7.5V.
Unfortunately 8V batteries are bandaids that only work until they run down.
