8 volt battery in a Super M
Posted by Paul A Young on August 27, 2014 at 20:31:45 from (69.161.39.42):
Never tried this before but today I put a 8 volt battery in a Super M because I have always been told that they will start so much better.Well it does turn over faster and starts quicker. The problem is the amp gauge now shows discharge when running. I did not change anything else,do I need to change voltage regulator or generator ?? All is well when you put a 6 volt battery back in.I'm puzzled. Paul
