Re: 8 volt battery in a Super M
Posted by gbs on August 28, 2014 at 20:04:23 from (71.51.254.63):
In Reply to: 8 volt battery in a Super M posted by Paul A Young on August 27, 2014 at 20:31:45:
most won't tell you but a 6 volt delco gen can produce 17 volts I have one with a 12 volt reg and know of a couple more set up the same way and they work o.k.,most will tell you that a 6 gen and starter can't handle the voltage, but they had to be able to stand the high resistance of a 6 volt system,one of the first ones I changed to 12 volts I still own it was done 35 years ago and still using the same 6 volt starter it was equipped with an alternator because at the time I wasn't aware of using a 12 volt reg
