Re: 8 volt battery in a Super M
Posted by pete 23 on August 29, 2014 at 11:00:46 from (173.87.12.198):
In Reply to: 8 volt battery in a Super M posted by Paul A Young on August 27, 2014 at 20:31:45:
Didn't say you need a Allen analyzing tool to set a regulator. Just noted I had one available at that period of time and used it. It makes for more accurate adjustments as you cam simulate a full charged battery which is what is really needed to adjust voltage regulation. Then you can place a load on system to check full current output. I don't own one either but dealer did. My point was that even doing things the supposedly correct way I still did not like 8 volt conversions. Sure some work out, most don't.
