Re: Farmall B Clucth drags
Posted by gurneejoe on August 29, 2014 at 19:57:15 from (98.193.54.109):
In Reply to: Re: Farmall B Clucth drags posted by Janicholson on August 29, 2014 at 19:28:48:
It was dragging when I first started it around memorial Day. I started it in gear and held the clutch down for a few minutws and it worked fine. Step on the clutch and pretty much down to a stop. It sat until today and now it is dragging again. I tried the same routine but it has a sticky spot if you turn the belt drive with the engine off there is a sticky spot. I can hold the belt drive with the motor running and turn it to the exact spot that it squeals. but a lot of squealing later it still hasn't worn off and the squeal is getting louder and more constant. The pilot seemed good and I greased the shaft when it was put together.
