Re: keep or loose 3 brush generator on super A
Posted by Owen Aaland on August 29, 2014 at 20:59:08 from (216.47.34.49):
In Reply to: keep or loose 3 brush generator on super A posted by mrl from ohio on August 29, 2014 at 15:01:28:
IH used a three brush generator with a voltage regulator for many years after discontinuing the generator used with the cut off system.
A Delco 10SI with a 6 volt regulator can easily replace your original generator and regulator if you want to go that route. They can even be set up as 6 volt positive ground if you want. The 6 volt regulators are one wire units so you only need to attach the wire from the ammeter gauge that goes to the regulator to the output terminal of the alternator to make the electrical connections. If using a negative ground system you would also need to swap the battery cables on the battery and the wires at the coil and ammeter gauge.
