Posted by mrl from ohio on August 29, 2014 at 15:01:28 from (162.213.224.3):
I have had years of charging problems with my super A Farmall, great little mowing machine when it works. The second regulator this year appears to have failed. I get 9V+ from generator when the F terminal is grounded. The generator is a 3 brush,I am told the regulator intended for 2 brush will not work and that i need a cut out and resistor controller for the generator. Adding up the cost of parts i"m told are needed to make this generator work, I"m nearly to the cost of converting to 12 volt alternator. Can this generator be made to work cost effectively, or is 12 volt conversion the most logical way to go?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
