putting starter on F20 with flex plate
Posted by wilson ind on August 30, 2014 at 07:35:34 from (162.235.98.33):
Fixing to put starter on F20 using flex plate and fabricate bracket for 12 volt starter. Question is anyone done this using flex plate that holes fit the universal coupling bolt pattern? Would like a 10 or possibly 12 inch size plate. any pictures of others mounting would be nice also. also what is the size of coupling bolt pattern on the F20. Thanks for any help or suggestions. Thought of trying to find heister set up but not wanting to pull flywheel
