You say it acts like it is not engaging the ring gear. Is the starter motor spinning when this happens or is it just a thud or click of solenoid. If starter is spinning it is a bad overrunning clutch in the starter drive gear. They can sometimes be difficult to detect when they are apart. Have to play with the gear trying to make it slip rearward. If just clicking or clunk, I suspect voltage drop through switch, starter button, safety start switch or wire. Easy test is to jump from battery connection at solenoid to small terminal on solenoid but that involves some danger as you need to have tractor in neutral and in park, throttle closed for testing purposes.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
