Re: farmall 806-Starter problems
Posted by rusticredacres on September 01, 2014 at 16:45:33 from (38.86.67.20):
In Reply to: farmall 806-Starter problems posted by avant tractor on August 31, 2014 at 17:52:11:
Check the wire going from start button to starter solenoid. Over years the harness will corrode inside wire coating and drop voltage. If you don't have proper voltage in wire it will give you false start or nothing at all. If you check the voltage and don't have minimum of 11 volts it wont energize solenoid. I worked at dealer and saw this numerous times. Those tractors are 50+ years old.
