WD-9 Thermostat
Posted by WD9ER on September 03, 2014 at 14:18:38 from (65.127.84.74):
Is anyone aware of a warmer thermostat for a WD-9? I have a black oily substance coming from the exhaust and I believe it is because the engine is not running warm enough. The thermostat was replaced when it was restored a few years ago and it never enters the "Run" range in the gauge (see attached picture). I do not know exactly what temperature the current thermostat is, but I believe it is 160 degrees.
I also need the exhaust pipe (P/N 6995DB) that muffler clamps onto to seal up the exhaust but have had no luck locating one. I guess that I will have to have the existing one turned down.
third party image
third party image
This post was edited by WD9ER at 14:19:15 09/03/14.
