Re: 53 Super C - Removal of Transmission Filler Plug
Posted by El Toro on September 04, 2014 at 08:40:08 from (96.244.7.206):
In Reply to: 53 Super C - Removal of Transmission Filler Plug posted by Newtractorguy69 on September 04, 2014 at 07:49:11:
Can you measure the square plug for size? Make sure you turn the plug CCW to loosen. You don't have any other choices in ratchet sizes. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
