Posted by Newtractorguy69 on September 04, 2014 at 07:49:11 from (204.6.91.240):
In working on some other items on my Super C that I am still getting used to I noticed that the transmission oil is low and I realized I should just change it. I did the research and know what fluid to use and where all the plugs are. My challenge, not very much of mechanic, is that the transmission filler plug has a square indent that would be used to unscrew it. I had been told that I could use a 3/4 ratchet but the ratchet fits loose and I fear that I will strip out the square hole in the plug. Any ideas of what type of tool to use to take out the plug? I think the drain plug sis the same with a smaller square.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
