Re: 1951 cub quits when hot
Posted by Denny ('60 Lo-Boy) on September 06, 2014 at 06:56:17 from (71.50.218.135):
In Reply to: 1951 cub quits when hot posted by John M on September 05, 2014 at 14:38:50:
Correct. It is a thermosyphon cooling system and has no thermostat. It also uses a no pressure cap on the radiator. Only fill it to where the tubes are covered, any excess is pushed out the overflow.
